I'm trying to reset my steering angle sensor, but am not sure where this connector is located. There is a small access plastic snap piece on the backside of the steering wheel with two yellow connectors behind it, but I think these are probably the airbag connectors. I also tried to remove the plastic housing covering the column behind the wheel, but even after removing the 4 phillips screws, these pieces will not come all the way off. What am I missing?
where is steering angle sensor connector? - ltullos12:58:56 11/13/11
